Use RegEdit32, and assign Standard User rights for these keys (for all the
trees)
- HKCU\Software\Autodesk\....
- HKLM\Software\Autodesk\....
- HKLM\Software\Microsoft\Windows\Explorer....
Alternatively, use RegMon from www.WinInternals.com, download
their free RegMon, and run it to monitor all keys, AutoCAD will access ....
The logfile may be saved - open this with a good editor, and "compact" this
file by editing & deleting lines, that report always the same Registry keys
This way, you will get an exact knowledge, which Registry keys AutoCAD
will access (writing) ... all those keys needs (better: the parent keys
only)
should be set to lower (Standard) User rights .....
Then the administrators will be happy ... 🙂
To automate the procedure, you can write a *.reg file, that will modify the
rights
for those parent keys ...
