i have 2004 LT running on my PC. The hard drive on this machine will need to be replaced next tuesday, Jan 15. I am sure I will need to re-register the license. I did when I put it on this machine. What steps do I need to take and whom do I contact to park the license? Thank You
You should be able to just install LT2004, then on first start it will walk you through the re-authorization required: just ensure your PC has a live internet connection and have your AutoCAD/LT serial number ready.
If you need further help or if there is a glitch, try this webpage for direct assistance:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
