Hi all,
Has anyone found a workable solution to the error message in the subject line?
I'm running LT 2014 on Win 7 64 machine. When plotting to "DWG to PDF.pc3" the error message appears. Very strange because it happened all of a sudden without any changes to my computer.
I've shutdown and restart. I've tried clicking and unclicking "Open in PDF viewer when done," background Plotting and Publishing, this http://forums.autodesk.com/t5/AutoCAD-2010-2011-2012-DWG/Publish-PDF-viewer-not-loading/m-p/3642902#...
Nothing seems to work. Any suggestions?
Thanks in advance!
Solved by pendean. Go to Solution.
Have you ever installed any PDF viewing tools yet? I wonder which kind of PDF viewer are you using? Any recommendation? Thanks in advance.
Best regards,
Arron
Thank you very much, your forum really helped me swim out of my problem from QuickBooks while printing W-2's for my employees.
Awesome
this does not seem to work for me. i have uninstalled adobe and reinstalled, restarted my computer and played with the functions the options menu in autocad as recommended. still running into the problem with " you do not have a PDF viewing application installed."
