AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
"standard" text was renamed and cause trouble...
6 REPLIES 6
c.dufrene
288 Views, 6 Replies
Hi guys,
Back to you with another issue...
We work with templates were the "standard" text style was renamed into C2, unfortunately this C2 style is used in blocks and toolpalette object therefore those are totally messed up...
I couldn't find a way to rename it back to "standard"
Any ideas ? (other than renaming C2 in all blocks and toolpalette objects...)
Thanks.
6 REPLIES 6
hwalker
in reply to: c.dufrene
Open up your template file
Click on FORMAT
Click on RENAME
A dialog box will pop up.
Look for TEXT STYLES
Click on it.
Choose the text style C2 and rename it.
Howard Walker
Left Handed and Proud
c.dufrene
in reply to: hwalker
If it was as easy, I won't ask it here...
Thanks anyway.
hwalker
Post your template here so we can have a look at it
And just for the record. Using the commands which I said. I just renamed my Standar to Banana
Howard Walker
c.dufrene
Arrghhh sorry, I read your answer too quickly and simply doubleclick the name Smiley Embarassed
Now it's ok.
hwalker
That's alright. We're only human
Howard Walker
Charles_Shade
RENAME can be called directly from the Command line without having to use the Format dropdown.
For those of you who do not Show (the) Menu Bar to save real estate in the Workspace.
”Boost
