This common XREF pathing error comes up when I open drawing sheets that were copied from one folder to another within the same project directory. Some XREF's in the drawing are relatively pathed and they show up fine, but the absolute paths display as "Not Found". None of the XREF paths have changed, and if I update the path (to the exact same path) AutoCAD finds it without any problem. This is a large project with hundreds of sheets, each with multiple XREF's, and I don't have time to go through and re-path every individual XREF on every sheet. Below is what I see in the XREF manager. None of the XREF file locations or names have changed from their original, and the opende file (93-201-A519-2B) was simply copied from one folder into an adjacent folder within the same project directory
Here is a view of the file structure within the project directory. All XREF files are contained in the XREF folder. The drawing sheets in question were copied from "3-CD" to "4-CA". Anyone have a good way to rectify the problem without having to individually update each path?
