AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
"Crazy Lines" when zooming or panning around
4 REPLIES 4
alli.falconer
4589 Views, 4 Replies
I'm not sure if this is an issue with my computer and AutoCAD LT 2015 or if it's a general issue everyone has.
If I am panning around a drawing with multiple objects, I begin to see line extensions going every which way from lines I have drawn. If I move a bit more, they disappear, but show up again when I pan and will ocassionally stay on the screen until I move again. I've attached images of what happens.
I have previously had LT 2010 & LT 2012 installed on this computer and never encountered this issue.
Is this an issue anyone else is having?
I use a Nobilis laptop running Windows 7.
4 REPLIES 4
pendean
in reply to: alli.falconer
So LT2015 is different, has a new graphics engine and all that, your older software did not. Things to try to help your laptop's video card cope with 2015:
Turn off LINESMOOTHING and LINEFADING variables (type them, 0 is off).
If that doesn't help, change the graphics card hardware acceleration in LT2015 as described here http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
alli.falconer
in reply to: pendean
Thank you so much!
Using the link you provided gave the solution. Using the GRAPHICSCONFIG command and turning off the hardware acceleration.
elliehays
I also had this problem.  I solved it by turning off the LINESMOOTHING and LINEFADING commands.  Thank you!
elliehays
in reply to: elliehays
as a post script, I also ended up turning off the hardware acceleration as well, with the GRAPHICSCONFIG command.
”Boost
