Probably your text is in a layer that is locked or turned off, try onlocking all layers, and make all layers visible
.....in the meantime, if the problem shows on most of your drawings it sounds as if the offending text is in one of your formats. Check those to find and remove. Doesn't help your current situation, but at least it won't be replicated in the future.
