AutoCAD LT General Discussion
Active Contributor
0 Kudos
Post 1 of 4
Accepted Solution
Question About Autosnap
111 Views, 3 Replies
05-01-2012 01:35 PM
I have the magnet setting OFF, and the Object Snap ON.
I draw a line, then when I add a second line, it automatically starts at an ENDPOINT, never at a MIDPOINT.
I can turn Object Snap OFF, and it stops, but I really need  to start lines at the nearest OSnap, not just the nearest ENDPOINT.
Just curious, since this is new, is there a different setting besides these two I'm using??
I assume that you have MIDpoint checked on?
What is your OSMODE Variable set to?
*Expert Elite*
370 Kudos
Post 2 of 4
Re: Question About Autosnap
05-01-2012 02:30 PM in reply to: FLHX
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
*Expert Elite*
1,590 Kudos
Post 3 of 4
05-01-2012 03:51 PM in reply to: FLHX
If you want it to always start at the MIDPOINT, youo need to only have the MIDPOINT object snap set (or actively type it).
OR
If you are going to have many other Osnaps set at the same time, them you need to ensure you are always near the osnap you want (midpoint of the line) and not nearest another osnap (endpoint based on your post) for it to work.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Contributor
0 Kudos
Post 4 of 4
05-02-2012 04:34 AM in reply to: FLHX
It was 4133.
I changed it to 16383, and I'm all set.
As usual, Thanks a million!
Post to the Community
New Post
