I have multiple pages I want printed. So I click on my "quick view drawings" on the bottom right.
I then click on "Publish"
It says that my project is publishing in the background.
This doesnt change. the publishing icon keeps moving and it looks like it is working but this will go on for hours, not advancing pages.
This used to have Autodesk Autocad 12 and it worked fine.
Anyone have any ideas?
Solved by pendean. Go to Solution.
I've experienced the same problem many times, usually for me it's something wrong with my printer settings or one of the pagesetups that is causing my printer not being able to recieve the data from Autocad causing it to stuck trying to send the information to the printer.
I suggest checking your pagesetups and printer settings.
Common problem for me when using "Use plotter named in page setup" was that one of the layout in the publish didn't have a printer set due to changes we've made, causing the publish to stuck.
Good luck
