AutoCAD LT Forum
Publishing problem
2 REPLIES 2
axiomcc
455 Views, 2 Replies
Publishing problem
I have multiple pages I want printed. So I click on my "quick view drawings" on the bottom right.
I then click on "Publish"
It says that my project is publishing in the background.
This doesnt change. the publishing icon keeps moving and it looks like it is working but this will go on for hours, not advancing pages.
This used to have Autodesk Autocad 12 and it worked fine.
Anyone have any ideas?
Tags (1)
2 REPLIES 2
AcadAdamLT
in reply to: axiomcc
I've experienced the same problem many times, usually for me it's something wrong with my printer settings or one of the pagesetups that is causing my printer not being able to recieve the data from Autocad causing it to stuck trying to send the information to the printer.
I suggest checking your pagesetups and printer settings.
Common problem for me when using "Use plotter named in page setup" was that one of the layout in the publish didn't have a printer set due to changes we've made, causing the publish to stuck.
Good luck
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
pendean
in reply to: AcadAdamLT
... you may also want to turn off background publishing too: OPTIONS command's Plot tab.
”Boost
