I have AutoCAD LT 2015. I upgraded from 2013. My OS is Windows 7 Professional. 64 bit
I used to be able to click on my layout tabs, (shift and select to get multiple layouts into one document) and print a multiple page PDF.
I have read through the library and I don't see an answer. It used to work perfectly. What has changed and how do I get this capability back?
Solved by pendean. Go to Solution.
It's not so complicated a process. I typically use dwg to pdf and that has worked fine. I'll look at what you say but I'm not sure that's the fix.
Well. For no reason related to this, I have regained the capability to print multiple sheets. I had a separate question about shortcut keys and reset the program to default settings and now it works. I can print multiple sheets. BUT I have lost all my ctb files (even though I chose to back the custom settings up) ARRRGH!
