AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Publish multiple layouts.
1 REPLY 1
AcadAdamLT
341 Views, 1 Reply
Trying to publish about 20~ layouts, all layouts are associated to a page setup which works correctly.
Publish option: Use plotter named in pagesetup
Everything should be okay but somehow the plot job is not sent to the printer, it just chews on it forever.
Why is it not publishing, any ideas?
If I plot with the same pagesetup one layout at a time its not a problem.
This happens in all drawings.
OS Windows 7 ultimate 64.
Hardware: More then enough.
Autocad LT 2014.
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
1 REPLY 1
AcadAdamLT
in reply to: AcadAdamLT
Turned off Background plotting and now it works...
AutoCad LT 2016
”Boost
