On choosing to publish 3 Autocad drawing files, all of which can be plotted individually, one file and others if I choose a larger selection, does not plot.
The "Device name" is missing on the resultant error list after the publish job has completed.
Yes, a fresh page set up on every page. Also I installed a local printer and renewed the page setup to avoid the risk of networks.
Import and test that pagesetup in each file's PLOT command, and see if you can more easily identify the issue.
