AutoCAD LT Forum
Publish - Error did not plot
3 REPLIES 3
7944 Views, 3 Replies
On choosing to publish 3 Autocad drawing files, all of which can be plotted individually, one file and others if I choose a larger selection, does not plot.
The "Device name" is missing on the resultant error list after the publish job has completed.
3 REPLIES 3
pendean
PUBLISH requires a pagesetup to be selected to be used: did you assign one?
in reply to: pendean
Yes, a fresh page set up on every page. Also I installed a local printer and renewed the page setup to avoid the risk of networks.
pendean
Import and test that pagesetup in each file's PLOT command, and see if you can more easily identify the issue.
”Boost
