Our GBIS group recently upgraded me to a new PC. They installed AutoCAD LT 2007 rather than the full version. Now I have some drawings that open with a window titled Proxiy Information and I don't seem to be able to turn that off. Any suggestions?
I also am not able to click on Tools, Inquiry, Distance (or Area) and have a result display. I click on the two points, but do not get a result. I can use dimension for distances to get what I need, but not for area. Any suggestions for this?
PROXYNOTICE variable, turn it off, usage explained in Help in LT.
PROXYSHOW variable, turn it on, usage explained in Help in LT.
That should take care of your first question I believe.
For the second, I'm going to take a wild guess since you do not really provide much to go on: your command line is set to only display 1 or 2 lines, instead of the minimum 3 lines and your dist/area answers are hidden. Expand the command line, or tap F2 key on your keyboard to see and confirm.
