This problem has been plaguing my program for months. On occaision my program will freeze up, the cursor changes to the hourglass and nothing happens. If I click the mouse the desktop fades out, then after a few minutes an "Insert Hyperlink" dialog box opens. I can then close that box and the work as usual.
I don't know what I am doing to trigger this command. I know I can launch the command by pressing F1 but that does not create the problem of the lockup and dialog box. I have never needed to use the command or use a hyperlink in a drawing so it is becoming very inconvenient and slows down my work.
First, does this happen to anyone else? and 2, is there a way to disable the command so I can't launch it?
see discussion at http://forums.autodesk.com/t5/autocad-2010-2011-2012/hyperlink-crash/m-p/5682023#M118690 - it's a bug in AutoCAD.
