Dear GegH1,
Did you ever get an answer/sollution for this problem?
I'm experiencing the exact same thing with two xrefs now in ACAD 2013.
kind regards,
Arjen
Never mind.
Found the sollution to my problem elsewhere on this forum:
Check "measurement" in both drawings and then reload all linetypes (or just
troublesome ones)
Measurement=0 is imperial =1 is Metric. Sets which acad.lin and
acad.pat it uses. (acadiso.lin is metric)
Once setting is changed, linetypes need to be reloaded to be correct if they
were loaded from incorrect file.
You should mark your solution as "Accepted as solution" so that others with similar problem can navigate to the solution.
Actually this would be better if ArjenK provided a link to the Thread that has the Solution and that that Thread is marked as the Solution. (Which it may already be.)
And the MEASUREMENT Variable is almost lost in the text of the answer
ArjenK should also look at the the MEASUREINIT Variable so that his work is all Imperial or Metric.
Since ArjenK did not originate this Thread he cannot mark as Solution and the subject line is a bit too generic to lead to anything that has to do with loading linetype files for Imperial or Metric setups.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Found it here: http://forums.autodesk.com/t5/AutoCAD-2006/Xref-linetype-problem/td-p/.UNG5SW872bM
But it was not the sollution in that tread...
