When I install AutoCAD appears error on stage Installing Language Pack.
Screenshot in attach.
Thank you in advance.
Search the Installation Forum for issues relating to Language Pack.
I had this issue pop up and there is a solution in that Forum.
You will need to remove the Language pack from the Registry entry to get rid of it.
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Thank you for quick reply.
I don't found the same problem in forum, but I tried different tips from forum, but without effect.
In another computer installation interrupted with the same problem (Internal Error 2709).
In attachment log file.
Do you have any idea, please?
If the above link with many solutions to try is not a fix, try a search of the entire Autodesk site, there are many topics that cover the error.
ENSURE you are logged in as fulll administrator in Windows before installing AutoCAD/LT.
