The problem is in the meeting of the two arcs in the little ends, all 8 of
them. They didn't meet correctly.
What I did was exploded it, and drew lines to section off pieces to see
where it could hatch. I eliminated areas to check, and narrowed it down.
In that attached drawing you will see it hatched, and also a little circle I
made in the offending location, which in my drawing is fixed.
To see it I had to zoom in as far as ACAD LT would let me while staying
centered on the intersection of the two arcs, and to do that had to regen a
couple times. I could then see a jag instead of a smooth meeting of the
arcs. It was still connected with a "jag" line, so I don't know why ACAD
would not accept the hatch.
But when I deleted the jag line (which then left two unconnected arcs), then
used stretch on one stray end to connect it to the other stray end, that
fixed it. Had to do it to all eight points.
After this it would not hatch with pattern "Angle" that was default in your
drawing, but it would with ANSI31. Don't ask me why.
Greg
wrote in message news:5686391@discussion.autodesk.com...
No, I do all of my drawings in dwg, but when I send one to someone outside
my company I usually save in .dxf for easier usage. I have posted the same
object as before but this one is still giving me problems, maybe it will
still give you guys problems to better illustrate what I am talking about. I
really appreciate all you guys' help.
