Hi, there. As you'll see I'm a complete newbie to this forum, but I've been asked by my company to look after software upgrades etc, including our AutoCAD LT users. I can log into the Subscription Portal with the username and password, but whenever I try to select "Download updated versions" I just get the below dialogue;
"Insufficient Privileges
You do not have the level of access necessary to perform the operation you requested."
I've tried submitting a 'case' about this error to AutoDesk on the Web support form, but I just got a message "You must log in before doing this" (I was logged in, at least to the subscription portal).
Any help would be really appreciated! All I really want to do is check if there are any updates I need to install for the users.
Tom
I too am receiving this error. As I am the contract manager for our system, there are multiple serial numbers which cannot be found by the Google search.
The login to subscription center (subscription.autodesk.com) behaves and looks like normal. The 'Get Your Upgrade' or 'Download Your Upgrade Now' links in the subscription appear to authorize correctly through SSO to the force.com portal. However, the force.com portal has changed and the following message appears:
Insufficient Privileges You do not have the level of access necessary to perform the operation you requested.
The welcome box in the page has my correct information, but all links appear to not authorize. I've attached a screenshot of the interface and error.
For subscription log-in help, ask at the subscription center, tap the ASK US button there and follow the instructions presented. Or post your question here instead where Autodesk staff answer most of the posts http://forums.autodesk.com/t5/installation-licensing/bd-p/24
These forums are end-users helping other end-users for the most part: like you, we don't have access to the inner-workings of Autodesk.
If you are just looking for a product download you should be able to find it at the Autodesk Customer Service Virtual Agent:
•In the preferences or options area of your preferred browser, remove pop-up blockers and allow access to all *autodesk.com sites.
•In the preferences or options area of your preferred browser, delete cookies, temporary internet files, and history.
1. Turn off your personal firewall or VPN, if you use one.
2. Disable UAC
3. Close and reopen your preferred browser.
4. Go to http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
5. Select the choice "Download Links".
6. Select your product, then variant, then version as applicable.
7. You should now be presented with the choice to download your software.
DWGTrueview 2014 download links can be found in this post:
http://forums.autodesk.com/t5/Installation-Licensing/TrueView-download/m-p/4427763#M68123
DTV 2015 64bit Download is here:
http://download.autodesk.com/esd/dwgtrueview/2015/SetupDWGTrueView2015_ENU_64bit.sfx.exe
Hello all!
We are aware of the current Subscription Center issues and the insufficient privileges error message. We sincerely apologize for the inconvenience but we are actively working on a resolution. I will notify this thread once the problem is fixed.
Thank you for your patience!
Please report when you will have the subscription center back up and running, I need to download my Design Suite Premium ASAP, thanks
Yes, please trying to install also.
It's working for me now.
Hello all!
All Subscription Center issues have been resolved. If any problems persist, please try clearing your cookies and cache or changing browsers. If issues continue after that please let us know.
Thank you all for your patience!
