AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Problem with HATCH
5 REPLIES 5
wrdk
149 Views, 5 Replies
Problem with HATCH
Somehow I can not define the boundary of a simple square. I'm using LT '07. It's a all closed in simple square and when I go to pick the internal point it can't find the boundary and chooses the whole drawing, ideas?
5 REPLIES 5
in reply to: wrdk
select the boundary instead and see what AutoCAD says about it.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
lrlandusky
in reply to: wrdk
Also, make sure you can see the entire boundary of what you are hatching. Sometimes AutoCAD can't recognize the boundary if it is not within view of the screen.
I've also noticed that it won't hatch large areas enclosed by a polyline. I often have to break up a length of wall and hatch it in two portions.
in reply to: wrdk
Turning off as many not-needed layers as possible overcomes your
second sentence issue usually.
Dean Saadallah
lrlandusky
in reply to: wrdk
Thanks, I will try that one next time.
in reply to: wrdk
Yes, I've found that it can get confused by too many other things
intersecting with your boundary. Turning off extra layers seemed to cure
that.
Greg
"Dean Saadallah" wrote in message
news:5686237@discussion.autodesk.com...
Dean Saadallah
”Boost
