My AutoCAD is having problem while saving the file.
During save the file "D02169M", the software keep pop-up a text told me that the file unable to save. See attachment A1.
and it was automatic create temp. file as
"atmp2740", "atep6851", "sav5318", "savC21E" and etc...... see attachment A2.
These will keep going on fill up my hard disk and my file "D02169M" was missing later.
Kindly advise. Thank you.
Solved by pendean. Go to Solution.
Read through this long thread, it has many tips to try:
http://forums.autodesk.com/t5/AutoCAD-2011/AUTOCAD-SAVES-DRAWING-TO-TMP-INSTEAD-DWG/td-p/2946584
