AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
problem in copying an attribute block from x.dwg to y.dwg
2 REPLIES 2
fatih
490 Views, 2 Replies
Hi to everyone.
When i am trying to copy my block which includes attributes from one file to an another (lets say x and y), only attributes can be seen in Y.dwg. There are no lines which are supposed to be there.
But it can be seen in block editor screen.
I checked lines' layer properties. There are no problems with that properties. I am out of solutions from now on. I have searched all web for a solution. However, i am unable to find one. I started to think I am the only one trying to cope with that problem in the world:)
I will be glad if anyone can help.
Thank you all.
Fatih Köstem
2 REPLIES 2
pendean
in reply to: fatih
Rename the block in the destination file (RENAME command), thaw/turn-on all layers in your destination file, then try again. Works 99% of the time.
fatih
in reply to: pendean
It worked! Thank you. Audit&Purge&Rename helped! 🙂
”Boost
