When I go to print to a pdf creator, I get the entire file location, including what layout, in the save as file name line:
S__AutoCAD_Drawings_Cabinet Drawings 625 and 1375_20104-02 Layout1 (1).pdf
What I would really like is just the file name, 20104-02.pdf, in this case to show on the file name so I don't have to delete a bunch of characters all the time. I had this on my old PC, can't seem to remember how to do this on the new one.
Thanks for your help.
I have included a picture.
Solved by lokimeister. Go to Solution.
What version of LT are you using? The newer ones can PUBLISH to PDF. And they will only have the file name in the saveas box
Howard Walker
There are serveral methords to create PDF file in AutoCAD LT.
1, Export > PDF,
The created pdf file name is same as dwg file name.
2, Print > Plot > DWG to PDF.pc3
The created pdf file name is <dwg file name>-Model/<Layout>.pdf
Methord 1 could match your requirement.
As I have already asked. Which version of LT are you using?
1. The newer ones when you choose publish there is a option called PUBLISH TO and the options are
Plotter named in pagesetup
dwf
dwfx
PDF.
2. In the same dialog box there is a PUBLISH OPTIONS.
One of the options is DEFAULT OUTPUT LOCATION (PLOT TO FILE).
You can change that to any directory you want.
Howard Walker
