Hi all.
I have strange situation at work.
My mate plot dwg to pdf and everything is ok - visible on preview, layers set correct etc...
When pdf is printed out some lines (even from the same rectangle) are kind of missing or when we change line to 0.05 from 0.0mm line are very barely visible and kind of dashed... looks like scale went wrong - he use AC LT 2012.
When he prints from model straight all looks fine.
PS. Same drawing printed out from different template printed out ok...:/
I did same drawing on my 2015 LT and all is fine when I plot pdf and print it out.
Any ideas what could go wrong, scale settings?
Solved by pendean. Go to Solution.
