No output devices are configured for Autodesk Plotter Manager.
Tried following online instructions for printer setup wizard....Output>Plot then Fatal Error (FATAL ERROR unhandled access violation) message came up and shutdown Autocad.
I cannot print anything from Cad.
Please advise
Thank you!
Kristin
Do you have a printer/plotter installed?
Can you print to it from other programs?
LT version?
Windows version?
Yes, I have both a plotter and a printer installed on my computer and can print to both from all other applications.
LT Version: Autocad LT 2011 32 Bit
Windows version: XP....3.46GB of RAM
Unless you have LT set up to hide system printers (OPTIONS command>PLOT-PUBLISH tab>HIDE SYSTEM PRINTERS), there is nothing to set up: just PLOT, select the one you want and all the parameters.
Is that the case?
I tried following those options and FATAL ERROR message came up again and shut down Cad. Attached is the screen shots.
Did this problem just start, or is LT new, or is the PC new?
Do you have any NORTON products installed? Remove them and restart your PC.
Autodesk recommended uninstall and reinstall procedures:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10243968&linkID=9240617
The PC and Autocad LT 2011 are both new, but NORTON is not installed on my computer and I have never been able to print.
Autodesk recommended uninstall and reinstall procedures: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10243968&linkID=9240617
Does Autodesk® Design Review software interfere with LT at all?
I am repairing Autocad right now and if that does not work I will try the uninstall/reinstall procedures.
Thank you!
It should not but sometimes these programs seem to hang on one another.
I've never had a conflict twix the two.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
