I am printing a document. The page I am printing is set up normally under the "Page Setup Manager", but for some reason when I hit the print button I get the following error message:
"Continuous plot log could not be opened for write." The only option on the error message is to click "OK".
The document prints out fine, and the continuous lines print out fine as well. Does anyone know why this error message is popping up, and what I can do to make this error message go away?
Thank you in advance.
Gorf
@Anonymous wrote:I am printing a document. The page I am printing is set up normally under the "Page Setup Manager", but for some reason when I hit the print button I get the following error message:
Gorf
2 options here. Apparently you do not have permissions to write where the log file is stored (not likely) or the locations is no longer there (more likely) or has been moved (the path has changed (prolly).
Controls options for saving a plot and publish log file as a comma-separated value (CSV) file that can be viewed in a spreadsheet program. To view or change the location of the log file, see the Files tab in the Options dialog box
My solution:
TOOLS > OPTIONS > PLOT AND PUBLISH tab
Left side low ... turn that sucker off.
DJ
