Either by buying a commercial license or (if you do already own a commercial
license) stop using content created on a "Not for commercial use -
Educational product"
AutoDesk Knowledge Base item:
http://support.autodesk.com/getdoc.asp?id=TS63668
Issue
When you plot a drawing that was created in or that contains drawing data
that was created in the Educational (Student and Faculty) version of
AutoCAD® or AutoCAD-based software, the following plot stamp or watermark
appears in the plot:
For Educational Use Only
Solution
There is no way to circumvent the plot stamp. This is as designed to
discourage the commercial use of an educational version of an AutoCAD
product. Autodesk sells educational versions of software on the
premise that the software will be used for educational purposes only.
This can also occur when using blocks or other components of drawings that
have been created or modified in an Educational version. This includes
layers, blocks, layouts, and so on.
ALSO if you have a commercial drawing that has an educational stamp:
We cannot assist you in this forum. This is a PEER TO PEER support group.
Help with this issue is only available through your Authorized AutoDesk
Reseller and the Autodesk Product Support group.
Contact your reseller and request a copy of EMR_STAMP.LSP (or EMR_Utility).
This is a lisp utility to search out infected files. If you have a few
infected files they can be emailed to AutoDesk for cleaning. If you have a
large quantity to be cleaned they have a 15 day program (involves
an approval process) that you can use to clean the files.
If needed please copy this information and email it to your reseller as this
problem may be something your representative may not be familiar with.
Please note that AutoCAD 2004 and AutoCAD 2005 include automatic detection
and warning of
the presence of Educational Drawing Files.
Tracy W. Lincoln, TLConsulting
Consulting, Design & Training Specialist
Autodesk Discussion Group Facilitator
Group(s) Index: http://discussion.autodesk.com
Product Support: http://support.autodesk.com
"jcyoungquist" wrote in message
news:29638232.1101796520982.JavaMail.jive@jiveforum2.autodesk.com...
> How do I plot in AutoCAD LT 2005 without the "AUTODESK EDUCATIONAL
> PRODUCT" text bordering all four sides of the paper?
