We are having a problem when plotting drawings to an Hp designjet 2500.
When we open a drawing just using the trueviewer it plots and printes to the correct scale,
however when we open the same drawing in the proper package it plats and prints at 4 times the scale.
Am i missing a setting .... or what am i doing ??
Welcome to the Forums
Can you post a screen shot of the print box that comes in when you print in Trueview and also one of when you print using Autocad.
Then we can have a look at the settings and point you in the right direction.
Howard Walker
it is printing 4 times as large as i require ... instead of on 1 page its printing over 4.
its building design suite standard
As I have said can you post screenshots.
But from what you have just posted it sounds like a PAPER SIZE problem.
eg. Your drawing is A2 yet you are asking it to print out on an A4 piece of paper.
There is a tick box in the plot dialog box titled SCALE TO FIT. Check that and print again.
Howard Walker
