I'm running Acad LT 2012 on a Win8 pc, using a DesignJet T520 24" plotter; no matter how i define the paper size, the plotter stops printing about 2" from the end of the extents, like it thinks i'm using a title block on 18x24 cut sheet media, even though the plotter dispenses the correct size sheet from the roll
Can anyone help with this, thanks
Solved by Tx1339. Go to Solution.
yes sir, the pdf file looks perfect; when i send that file to the plotter, it cuts off the same 2" or so as if to fit a cut sheet 18x24 with title block, but it still dispenses a 24x24 sheet from the roll
i updated the driver, along with some additional tweaks to the driver setup, i can now get one good plot after a restart of the plotter, on the second plot it reports out of memory and suggests sending the printjob as a bitmap; don't really understand the difference, and find it hard to accept that the simple 2D diagram i'm plotting would need more that 4gb of memory, but at least now i can get a successful plot, so thanks for your help
