Ok I only use LT2005, but this should work (touch wood)
First make sure all your page setups are in a template file. Then when you start a new drawing use that template file and all your page setups will be in your drawings.
Second in LT2005 there's a command called psetupin. It allows you to import a page setup from any drawing you choose.
Howard Walker
Left Handed and Proud
