AutoCAD LT Forum
PEDIT won't convert from line to polyline
5 REPLIES 5
madcowscarnival
4547 Views, 5 Replies
There is a post very similar to this, though it has something to do with how a drawing was exported from another program.  My problem is: the PEDIT command won't give me the option to convert a line "I" add to a pline.
PEDITACCEPT: 0 or 1, problem remains
It is a drawing from an house designer, I am adding structural members and notes over the drawing.  I could xref, but I need to move/erase some of their notes as well.  It becomes cumbersome to switch to the source dwg, edit & save, move to current dwg and refresh, to have the note where needed.
This is a pretty strange to me drawing file.  It seems that a bunch of system variables are altered and hopefully it doesn't migrate over to files originating from my machine.
Thanks for any ideas in advance.
5 REPLIES 5
pendean
in reply to: madcowscarnival
Does PEDIT give you an error message?
You also want to add the "line" to an existing PLINE? Is there a gap (the ends of the two objects don't meet)?
LIST command and select one of these "lines", see if you can confirm the object is a LINE entity and not something else.
madcowscarnival
in reply to: pendean
Apparently this is something I've just never tried to do before.  Assign a pline->width to a circle.  It was my assumption that as it worked on all other shapes, it would work on a circle, it doesn't.  I guess a closed arc will suffice.
Is this the case?  It just won't convert the circle into a pline.
pendean
Correct, does not work on Circles: try a DONUT instead (yep, it's a command not a smartass reply LOL).
You could always BREAK the circle, turn it into a polyline with width, then EXTEND the polyline arc
hwalker
in reply to: ScottHodges
You can create a polyline circle yourself, but it can be temperamental at times
Choose you start point. Press A for ARC, choose the direction at type the diameter of the circle, and then close.
Howard Walker
Left Handed and Proud
”Boost
