Hi Dean
Is it possible to convert a PDF drawing to a DWG if it is other than text,
i.e an actual construction drawing?
"Dean Saadallah" wrote in message
news:A330CE59C84D534A362805E80ACBC0D7@in.WebX.maYIadrTaRb...
> First, you should ask the PDF file creator: maybe they don't want you to
> have a DWG of it, or they do have one but it is not posted. It's always
nice
> to ask permission first.
> PDF to DWG:
> PDF -> Adobe Illustrator -> DWG/DXF -> AutoCAD
> PDF -> GhostScript + GSView + PStoEdit -> DXF -> AutoCAD
> PDF -> Adobe Acrobat (free or full version) -> Copy/Paste -> AutoCAD
> Open Adobe Illustrator version 10 (if you have it, if not, might
> want to consider buying it), open the PDF, then Export to DXF format.
> In AutoCAD, open the DXF file and save to DWG.
> Get the freebie tools GhostScript + GSView + PStoEdit from the
> Internet (any search engine will help you find them all), install
> them all in the order noted above, download the quirky help files
> that go with them, then open the PDF file in GSVIEW, then you use
> the Edit>Convert to vector format... and pick the DXF option.
> The result is not 'pretty' or convenient though.
> Adobe Acrobat, use the Graphics Select Tool, select the graphic(s)
> you want to bring in, right-click and select Copy, then in AutoCAD
> right click and select Paste: now you have an OLE image of the graphic to
> use in AutoCAD.
> If you use the Text Select Tool in Acrobat, use PASTESPEC in AutoCAD
> to bring it in as an MTEXT block: current text style settings apply.
> This assumes the text in your PDF is text, and was not saved as graphics.
> Dean Saadallah
> Add-on products for LT
> http://www.pendean.com/lt
