Solved by sthompson1021. Go to Solution.
Hi Dean,
I'm referring to the timestamp on the file in the Windows dialog box, as seen in the attached file.
The pdf was created only minutes before the dwg was last saved, but the timestamp is way off. The time on the dwg is correct. The PC time is correct. I have tried this on a clean reboot with nothing else running, with the same result.
Hi, there was a similar problem a couple months ago. Here is a link to that thread.http://forums.autodesk.com/t5/AutoCAD-2013-2014-DWG-Format/Wrong-date-on-DWG-to-PDF-files/td-p/38756...
