I was trying to plot a drawing from a file that someone else sent me, and plotted it from a dwg to pdf which seems integrated into AutoCAD 2015. It did give me some messages about a device not being found when I was setting up the plotting, but I don't remember what was written. When I sent the PDF to FEDEX they got a message saying
"There is an error opening this document. The file is damaged and could not be repaired." What could I have missed doing? What would have been the device that was missing?
Many Thanks
Solved by pendean. Go to Solution.
Hello
Q1) Have you opened your DWG in Recover Mode, then Purge, Then ReSave, then ReTest ...
Q2) Have you installed on your ACAD LT 2015 the SP 1 and/or the SP 2 ?
Q3) If SP 2 , have you installed the BigFont Patch Post-SP2 ?
Q4) Have you yet an other ACAD LT on your PC ?
If YES, which one ??
Q5) Which PDF driver exactly ?
Patrice BRAUD
Hello
Q1) From a blank DWG (or NO DWG opened) , Click on the Big Red A (Top left) then Recover / Recover and you open your DWG in RECOVER Mode !
Then always from the Big A , Utility then PURGE everything many times if necessary !? ... ReSave the DWG ...
Q2) On teh text/command ACAD Line : ABOUT <Enter>
On the second line (Top left), do you see "SP1" or "SP2"
If nothing, I would like that you install the SP 1 (NOT the SP 2) for ACAD LT 2015 :
http://knowledge.autodesk.com/support/autocad-lt/downloads/caas/downloads/content/autodesk-autocad-l...
Q3) Not concerned
Q4) How do you produce (or try to) your PDF file ?
EXPORT or using with print/plot a PDF driver: "DWG to PDF.pc3" or "PDFCreator" or "Acrobat Pro" or etc ?
Patrice BRAUD
