Everytime I try to export my dwg to a pdf file I receive the mesage "Fatal error: unhandled c0000417h at 73800468h" and AutoCAD 2013 LT closes. I need to export to share files. Any Ideas on what may be causing this?
Thank You for the suggestion but it will not create an Adobe PDF file. It does not crash with a Fatal error but will not create a .pdf file I can open with Adobe Acrobat. It does sometimes create a .plt file and other times returns with an error message that it can not create file. I did this regularly with ease on AutoCAD 2005 but 2013 is less useful and freindly?!
I am not sure if there is a setting in the plot and publish configuration or something else.
Thank You!
Tracy
DTSDesignStudio
