AutoCAD LT General Discussion
EL-Designer
Message 1 of 12 (774 Views)
paste issues again!!
774 Views, 11 Replies
11-16-2012 07:34 AM
I got an issue with paste command again!!
I am working on a drawing with 20 pages, I have to copy some texts in all drawings and I did it for 19 pages but suddenly I can not paste it in last page!!
And surprising that I can not paste anything in the drawing anymore!
I have tried to paste with clipboard but doesn't work!
even I copy from other drawing, Can't paste it!
this is the error that I'm getting:   " Substituting [simplex.shx] for [MSURVEY.SHX] "
even I reload this file it doesn't work :smileysad:
Thank you to everyone engaging in assisting in this post.  One suggestion moving forward would be to perform a total clean up procedure on a test copy of this affected file using the sequence outlined in the link below.  This will then strip out all potential problems and create a new, fresh, cleaned up file for use.  This also works for many other scenarios of corrupted or lagging files.
File clean up: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18809891&linkID=9240617
Charles_Shade
Message 2 of 12 (770 Views)
Re: paste issues again!!
11-16-2012 08:15 AM in reply to: EL-Designer
Do you have the MSURVEY.SHX Font?
Assuming you do but if not you need that SHX Font or change the Textstyle that uses it to one that you have.
BTW - I did have a SHX font become corrupt the week or two ago. Never did find out why.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
EL-Designer
Message 3 of 12 (757 Views)
11-16-2012 01:13 PM in reply to: Charles_Shade
how can I fix corupted SHX file?
pendean
Message 4 of 12 (753 Views)
11-16-2012 01:25 PM in reply to: EL-Designer
20 pages: as in 20 different DWG files, or 20 layouts (or 20 locations in one modelspace)?
What is clear is this one "file" you cannot paste into, perhaps the layer is frozen or it is a file from another source with AEC content in it? I seriously doubt an SHX corruption is the problem.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Charles_Shade
Message 5 of 12 (728 Views)
11-19-2012 05:11 AM in reply to: pendean
Offered that as a reason why the OP's file may no longer be recognizing the SHX font.
Isn't a SHX issue something that another poster had a couple weeks ago when trying to paste into a drawing?
It was missing therefore the paste would not finish?
EL-Designer
Message 6 of 12 (720 Views)
11-19-2012 07:14 AM in reply to: pendean
It Is one drawing with 20 layouts, there is no frozen layer!
I van not past anything!! its so wierd :smileysad:
Charles_Shade
Message 7 of 12 (715 Views)
11-19-2012 07:40 AM in reply to: EL-Designer
Ran AUDIT on the file?
Tried WBLOCK to a new file?
EL-Designer
Message 8 of 12 (702 Views)
11-19-2012 12:42 PM in reply to: Charles_Shade
I audited the drawing, still doesn't work.
I made a block from the objects that I wanted to copy when I want to paste it, I can see it on the clipboard but when I click on the page something else will pasted that I have no Idea where that come from?!!
pendean
Message 9 of 12 (690 Views)
11-20-2012 04:48 AM in reply to: EL-Designer
so the problem is one single file? Post it here, remove any sensitive info first. Share your font too, use ETRANSMIT command to package a ZIP file to post and inlcude everything needed with the file.
EL-Designer
Message 10 of 12 (681 Views)
11-20-2012 05:59 AM in reply to: pendean
I opened the drawing today and it works fine!!
I have no idea what happened !
but please let me know if someone found a solution!
