I am using Autocad LT 2011. In paper space, the area outside the plot space is a light gray in color. In 2010, I could paste items such as notes and other blocks that are white in color and place them in this area until I had my plot organized. In 2011, when I do this I can barely see the items. Is there a way to darken the area up a little so my items are more visible? I find myself going back to 2010 just to avoid this problem.
Thanks for any help.
Ron
Solved by pendean. Go to Solution.
Tools, Options, Display, Colors
Pick and choose...Pick and Choose...
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I have been here. I chose sheet/layout then background and selected black. my plot area is black just as I want. It is the area surrounding this that I am trying to change. I don't know what it is called so I don't know what to select. Can you help?
Ron
Turn off Display Paper Background in Options>Display tab>Layout Elements is about all you can do.
A little more exreme than I was expecting to go but it does solve my problem. Thank you for the tip.
Ron
Being the wild fronteirsman that I am, I not only have that unchecked, but also the one about displaying the printable area ( the dashed box)
