OVERKILL has been introduced to the LT community with the release of LT 2012.
What, if any, unexpected deletions, problems, or other items should I look out for when using it?
My first foray erased odd portions of a door that I did not expect to happen. What else may crop up? Or not?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Solved by pendean. Go to Solution.
Which I think are the questions at the heart of my query.
They may very well have been PLINES. This particular Block has some sprinkled thru it.
As far as what Options are chosen I have not gotten that specific yet.
Over the years, the attached screenshot from R2011 has never failed me. Also attached is the R2012 version.
Thanks, that's what I'll do.
love overkill made our lives a lot easier
have a factory layout cobled together from multiple vendor drawings with exploded 3d and 2d different styles formats etc etc
run overkill over the drawing reduced the size from 7mb down to 4mb
runs smother doesnt crash as often what more can i say autodesk got this command right for us
Admin - Not sure why you moved this but adding the info to the LT Forum makes sense.
My posting in the AutoCAD 2012 Forum was because I expected to recieve responses from AutoCAD users who had experience with the Command.
(And yes - I could have gotten Dean here too.)
