AutoCAD LT Forum
orientation of text in layout
4 REPLIES 4
agnesbt
312 Views, 4 Replies
When i add text to a layout it plots vertical not horizontal as add and shown in the layout. Is this a setting issue?
4 REPLIES 4
hwalker
in reply to: agnesbt
Has your current text style got vertical set as an effect?
Also, are you using single or multiline text?
If you are using single line text. Do you just select the start point of your text and then press enter twice. If so do not do that press enter once for the text height and then make sure the orientation of the text is 0 degrees
Howard Walker
Left Handed and Proud
pendean
Can you post a DWG with this problem? Plus a PDF to show the final effect you are experiencing.
agnesbt
in reply to: hwalker
Thanks for the help.
Turns out i need to pay more attention to the settings when i change text styles and layout orientations.
agnesbt
in reply to: pendean
problem is solved.
”Boost
