AutoCAD LT Forum
opening lt98 drawings in lt2015
2 REPLIES 2
M_PULLEN
262 Views, 2 Replies
When I open drawing files created or edited in LT98 the screen displays (and plots as well) many lines not on the original.  They possibly are extension lines or connect objects, however, I cannot select them to simply delete them.  When I do select the drawing  by lasso I am prompted to "Edit nonassociative hatch boundary grips"  The lines don't really appear to be part of any hatching though.
I appreciate any insight.
2 REPLIES 2
hwalker
in reply to: M_PULLEN
Welcome to the Forums
I had a similar sort of problem before. I opened up some drawings in LT2012 which were created in LT2008 and I kept on seeing a red or white block (which I could never see in LT2008)
It turned out this was a hatch pattern which was a single point (so to speak).
What I suggest you do is either
select all hatch objects in the drawing and delete them or
post the drawing here so we can have a look at it.
Howard Walker
Left Handed and Proud
M_PULLEN
in reply to: hwalker
Thanks for the reply,
I ended up working around the problem by turning off the graphics accelerator.  If it is a recurring problem I will try your suggestion to clean up the original drawing.
Thanks again.
”Boost
