AutoCAD LT Forum
opaque blocks
6 REPLIES 6
BENNYMONE
7440 Views, 6 Replies
opaque blocks
Hi, I have made a block which is simply a triangle, but i want to make this block opaque (non-transparent) so as i can place it on top of a line and not see the line. Can anyone help??
Thanks.
6 REPLIES 6
ljshive
in reply to: BENNYMONE
Apply a solid hatch?
BENNYMONE
I cant do that becasue when I print it out I want it just to be white??
ljshive
then I think you want to use wipeout command
That only happens if you only do as suggested: take the extra step and
assign the solid hatch a color 255, then adjust your plot style table for
zero screening for that color (with dither and grayscale off) and you get
no-color (your paper background shows).
Dean Saadallah
http://LTisACAD.blogspot.com
Wipeouts are still problematic when plotting to older devices and older PDF
drivers.
Dean Saadallah
BENNYMONE
Cheers very much, Id never heard of that command before, it worked a treat.
”Boost
