AutoCAD LT Forum
OLE object (Excel sheet) to report ?
2 REPLIES 2
SolarCadTech
486 Views, 2 Replies
after i insert an excel sheet into a drawing and fill it with the relevant data, can i somehow export that into another excel sheet as a report ? in other words, is there a way to link what i type into an ole object into an independent MS Excel sheet ? of course i'm looking for a streamlined method to do this, so the data entry is only done once. thanks!
autocadLT2011
i7-M620@2.67GHz
8GB ram
64bit
2 REPLIES 2
pendean
in reply to: SolarCadTech
"insert an excel sheet" how exactly did you do this?
SolarCadTech
in reply to: pendean
"insert" as in ole object..
however, i found a way around it (or a reverse way around it).
i use a "chart" which is data-linked to a specific excel sheet.
i enter the data into 'that' excel sheet and update the chart in acad.
that way i get my excel reports, and autocad drawing done with one data-entry menouver.
cheers!
autocadLT2011
i7-M620@2.67GHz
8GB ram
64bit
”Boost
