AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Objects disappeared from tool palettes
3 REPLIES 3
toto2
272 Views, 3 Replies
For some reason, all of my customized objects in my tool palettes have disappeared. The tabs themselves are still there, but everything on them is gone. I found all the files for my missing objects listed in my Tool Palette folder and I verified that the the path is set up correctly. Has anyone else had this happen or can anyone suggest what may have caused this and how I can fix it before I go to all the trouble to re-do my tool palettes? I'm currently using LT '07 on Windows XP.
3 REPLIES 3
in reply to: toto2
Perhaps you just need to reload your TPs: did you export and save them for
archiving previously?
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
in reply to: toto2
had the same problem, except my vent 3D objects appear but the piping 3d objects dont appear.  I used the takeoff command but nothing.  Any suggestions?  Thanks
pendean
takeoff command?
”Boost
