AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Object redraws or rerenders during Move command
3 REPLIES 3
casey
694 Views, 3 Replies
Please see the linked video. I reinstalled Autocad LT 2013 and it did not help.
https://www.dropbox.com/s/exhvgqwhfdjzuwz/IMG_3632.MOV
Casey
3 REPLIES 3
bgingerich
in reply to: casey
There is not a LT fix for this.  This is normal on a computer with lower specs.  What are the specs for your box?  Is it just the baseline (i.e. 2gb ram etc...)?  If so then this is to be expected; better performance comes with better hardware.
May I ask why it is imperative for you to see all the objects you're moving?  If you pause while in the middle of the move command, you should see things starting to come back.
(if ("mysolution"=answer) then (click "Accept As Solution"))
Brandon Gingerich
casey
in reply to: casey
Charles_Shade
in reply to: casey
”Boost
