Dean,
XLOADCTL = 0
VISRETAIN = 1
XEDIT = 1
I had already disabled demand loading of xrefs & the others are the default.
I tried a suggestion from another post that seems to have solved the
problem. I added "Program Files\Common Files\Autodesk Shared" to the search
path in LT. I do not know what is there, but I find it odd that I would be
the first to experience this problem.
Thanks for your help,
"Dean Saadallah" wrote in message
news:CDE852641C7EE95AA3D87F448CB4B4A3@in.WebX.maYIadrTaRb...
> What are your XLOADCTL, VISRETAIN and XEDIT variable settings?
> Dean Saadallah
> www.pendean.com
> "Lysle Gordon" wrote in message
> news:89215AE40E59D06B2A27206761A7D11E@in.WebX.maYIadrTaRb...
> > I just tried that and it does not work. However, if you leave the xrefed
> DWG
> > open and then open the master DWG the objects do clean up correctly. If
> this
> > is necessary it is a major pain in the derriere. I am hoping for a real
> > solution, not a kludgy work around.
> > Thanks for the hint.
> > news:E3D666B9D722E3D5F0B28614636D99AB@in.WebX.maYIadrTaRb...
> > > Have you tried to open the Xref files with the OE enabled LT and
saving,
> > > before you open the master file?
> > > Dean Saadallah
> > > www.pendean.com
> > > news:CFFD6906416D5D2C4EED9FC1D1B72A4E@in.WebX.maYIadrTaRb...
> > > > We are trying to use LT2002 with ADT 2. I have loaded OE 2.53i, but
it
> > > does
> > > > not clean up walls in xrefed drawings. It seems to work OK if the
plan
> > > > drawing is opened directly. We use xrefs extensively for plotting. I
> did
> > > not
> > > > want to try OE 3.3 because a save would convert the arch objects to
> ADT
> > 3
> > > > objects.
> > > > Any ideas?
> > > > Thanks.
