I have recently been given a copy of Nuance PDF converter professional for use with my AutoCAD LT 2009 that I use at work, I have been using Adobe for years now without issue, but IT upgraded my PC and took my old one away and gave it to the junior CAD operator in the office, I've only had it installed for a few hours before it played up on ACAD, for some reason it is cutting off text within my title block, the title block itself is fine, but it seems to be a line running up the rhs of the page that is cutting off text, I have had re-PDF'd it in Adobe and this issue does not happen, only with nuance,
Does this happen with anybody else? has anybody found a way around it, or is it user error and something i'm doing wrong, i have used the built in PDF driver but the quality is poor and the file size is massive in comparison,
Cheers
You'll probably find it's something to do with nuance and page margins.
I use Pdfcreator to make my PDFs it's works a treat
Howard Walker
I'd file a repair ticket request with the IT department. And if they didn't fill it start sending them all my files to fix.
Dave.
