when i want to use hatch in autocad 2014 LT, autocad stop working.
wheni chose my settings like pattern and scale everything is just fine.
afteri select a field for hatching autocad stop responding.
thishappend 9 out of 10 times...
im running service pack 1. i hope someone have a solution for me.
sorry for my bad english!
see the attachment for the error code.
Solved by maxim_k. Go to Solution.
Welcome to the Autodesk Forums!
Does AutoCAD stop working in such a way even with simple drawings (when you define hatch area inside rectangle which is only one visible in drawing area)?
Finding hatch boundaries is not a trivial task for AutoCAD, especially if you have a lot of objects in current view, and doubly difficult if there are a lot of blocks and/or splines in current view.
It seems that Windows "thinks" that AutoCAD doesn't respond, but in fact it (AutoCAD) looking for hatch boundaries at this time an it takes a lot of time for it.
Have you tried to narrow the task for finding boundaries by turning off unnecessary layers (or hiding unnecessary objects), or by defining new Boundary Set with window (you can access this option from Hatch Settings dialog or from Ribbon:
You can also turn off hatch preview during hatch creation - set variable HPQUICKPREVIEW=0
Maxim
HPORIGIN to near the area to be Hatched can help.
Add a no-print divider in the area to be Hatched and Hatch both sides separate.
I have Macros for commonly used Hatches that turn off many Layers that are not needed for the Hatch so there is less for CAD to think about.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
This moves the Origin Point (Coordinate) of the Hatch to an area near the Hatch.
I tried to add hatches to my autocad (2014), but since I add them my hatch command doesnt works. Every time I try to use it, my Autocas stops working. I 've already tried to unstall and install autocad... but it didn't fix the problem
Hatching is literally the worst command in autocad. It freezes all the time and you have to jump through so many hoops just to get it to kinda work. Would be nice if the newer versions would focus on fixing stuff thats been bad for years instead of added a fancy new gui that no one cares about.
