I get a "Not Applicable" error message within 60 seconds of opening AutoCad LT 2005. Happens EVERY time and it never happened before. I reinstalled the program. Still happens. Program closes and I have to open again, hoping I can excercise at least one command before it occurs again. Prompt tells me to tell Microsoft about the problem. Microsoft won't help since ACad isn't a microsoft program. ACAD won't help since the version is a "retired" program. Problem doesn't happen on my laptop, only the desktop. Any one out there with advice?
Windows>Restore is what you do to fix an issue that did not exist the day before (unless this is a brand new install, which you did not indicate).
If a repair reinstall of LT did not fix it, there is either another app or update/orsomething that got installed, or removed, that messed up LT. Autodesk recommended uninstall and reinstall procedures are:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10243968&linkID=9240617
Thanks Dean,
I didn't do a repai reistall of the program, just a standard reinstall/ I will try that. Thanks for the link.
Chris
