Just recently purchased AutoCad LT 2015.
I am running windows 7 (service pack 1) 64 bit. Digial Storm Computer, Intel Core i7-4710k CPU, 3.50 GHz, 8 GB Ram. This is a high performance computer.
I downloaded the software and when i go to open the file, this is the error I'm getting:
"Unable to find software for the selected file"
"File Name: AutoCADLT_2015_SWL_English_Win_64bit_dlm.sfx [1]"
Does anyone know what I need to do next.
If you are just looking for a product download you should be able to find it at the Autodesk Customer Service Virtual Agent:
•In the preferences or options area of your preferred browser, remove pop-up blockers and allow access to all *autodesk.com sites.
•In the preferences or options area of your preferred browser, delete cookies, temporary internet files, and history.
1. Turn off your personal firewall or VPN, if you use one.
2. Disable UAC
3. Close and reopen your preferred browser.
4. Go to http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
5. Select the choice "Download Links".
6. Select your product, then variant, then version as applicable.
7. You should now be presented with the choice to download your software.
DWGTrueview 2014 download links can be found in this post:
http://forums.autodesk.com/t5/Installation-Licensing/TrueView-download/m-p/4427763#M68123
DTV 2015 64bit Download is here:
http://download.autodesk.com/esd/dwgtrueview/2015/SetupDWGTrueView2015_ENU_64bit.sfx.exe
